Well, I've been reading for 2 months and asking questions here and elsewhere for almost as long. I've made my choices on a plasma water table system for home/small business jobs and this is what I've come up with.
I've purchased the Candcnc Dragoncut 620x4 package with THC, Shopdroid Ultimate Geared Reduction running on IVTAAS and G v-groove rails and the TNG Z, a Hypertherm PM45 with machine head and also a hand torch, Mach 3 and Sheetcam. Everything has arrived and the design continues on the water table setup.
I want the table to be able to drain. I'll likely use 2 x 1/8 stock for slats and I'll build the table to sit on adjustable feet but also with locking iron casters that can each take 1000 pounds. The casters will be mounted to flip down and lock into position to move the table around. I need to do this for 2 reasons- 1: the garage space is very small so it will often sit in a corner or must be moved to accomdate other jobs, and 2: I have an auto hoist that I intend to use to load heavy plate onto the plasma table with... Back the truck in, lift the plate up and off the truck, wheel the table underneath then lower the plate onto the table... The table will never be used sitting on casters. Period.
I bought enough stock to build a 5 x 10 table but will likely go with 4 x 8.
Who says go for 5x 10?? Who says go for 4 x 8?? I dunno yet...
I've read that the longer IVTAAG extrusions torque under rapid accel and decell and know that beefing the extrusion up may be needed. I hope to understand the flexing situation before the build is finished and have a remedy for it. I do have a boat-load of aluminium angle and a massive aluminium extrusion for a centre section of an aircraft wing spar to play with, too.
Here are some poser pics for the time being. I'm working on the table design right now and hope to have it finished in 3 weeks.
The bracketry and whatnot. The gears need to get drilled out to 3/8 and new set screws drilled into place.
The new Hyperterm and candcnc goodies.
28 feet of gear rack
The long awaited for IVTAAS and G in good shape after a cross-continent delivery.
So please everyone- don't hesitate to offer suggestions. I'm a real computer nerd and wanted to use Linux and EMC but the candcnc just had too great of a reputation. I couldn't ignore it. I've built, soldered and programmed a couple of awesome working 3D printers but have never seen a real plasma table before in my life. I just know I need one for a job I have to finish at home and want to do jobs for others around where I live as a part-time job at home.
Here's the project that I'm working on at home:
Jim's new hybrid Scrambler build- tons of questions coming! - JeepForum.com
Thanks, Jim
