The sales volume of horizontal machining center, which is manufactured by our Jasu Precision Machinery, have exceeded 50 set in this month(May). Jasu horizontal machining center include two series: 3-axes liner guide dynamic column horizontal machining center and 3-axes dynamic column horizontal boring and milling center. These two series are patented product of our company.
Horizontal machining center is designed and named comparing to vertical machining center. Generally, the vertical machining center is small with small power, so it is not available to machining big parts. Therefore, some big size components shall be processed by bigger horizontal machining center. As for Jasu horizontal machining center, whether the important inner core components or the plate metal outside, they are all selected and tested by our engineer carefully and manufactured by our worker seriously. The failure rate of our machine is very low.
We, Jasu machinery, started in the cnc machine field late, but we have designed and developed many our own patented machine. What’s more, we have exported our machine to Europe and America. The influence in the machine tools industry is becoming more and more powerful.
3-axes liner guide dynamic column horizontal machining center is one of the series, including the model H-630, H-630S, H-800 and H-800S. The products of this series is designed with European automatic dynamic column. The worktable can make good rotary motion, also double exchangeable worktable can be installed. The three axes adopt linear guide with high bearing capacity, high accuracy, and high speed. It is easy to operate and suitable for parts volume production.
As for the other series, 3-axes dynamic column horizontal boring and milling center, it includes the H-1400T, H-1900T and H-2300T, which is designed in Europe style with high rigidity.
Jasu Machinery not only absorb the advanced technology overseas, the more important, we make innovation based on our own characteristic, manufacturing advanced cnc machine and making indelible contribution to our cnc machine industry
