588,687 active members*
6,485 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > HF 7x10 MiniLathe - Bar mounting
    Dec 2009
    82
    Hi.
    on the HF 7x10 Mini-Lathe, can you mount a bar through the chuck like you can on larger lathes, so that you can work on the end of a long bar?
    I have some 15" long rods, that I just need to drill and tap the ends of. (But I also want an excuse to get a new toy).
    Mar 2004
    1306
    Yes. The spindle has a 20mm (approx) bore. The 3" three jaw check which comes with it only has a about a 16mm bore.
    Regards,
    Mark
    Dec 2009
    82
    Great, thank you.
    Feb 2010
    Just be careful the end of a longer bar doesn't start to whip around.
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
  1. cummins minilathe
    By krymis in forum Mini Lathe
    Last Post: 02-07-2010, 11:01 AM
  2. Casting round alum. slugs for minilathe
    By dmerc in forum Casting Metals
    Last Post: 05-22-2009, 04:12 AM
  3. Replies: 2
    Last Post: 01-26-2009, 08:50 PM
  4. Seeking Minilathe QCTP Advice
    By HankB in forum Mini Lathe
    Last Post: 02-09-2008, 03:29 AM
  5. Canadian Source for MiniLathe other than Busy Bee
    By yukonho in forum Mini Lathe
    Last Post: 01-29-2005, 10:00 AM
