Not sure if this is in the right place but.....
I have a micro lathe (C1), yes I know...very small, etc etc, however is perfect for what I use it for, have even CNC'd it!
Anyway, the only real thing it lacks is power, the motor is only 150watts (I have still managed to turn down 60mm alloy bar but did take a while). I have read a lot about replacing lathe motors with those from treadmills, but here in Australia they are a little hard to come by, but have found quite a lot of Electric Scooter motors (you know, the ones that the elderly people use to run you down with in shopping centres!).
They seem to have the right rpm (usually up to around 2750), 20 to 35 or so amps, would obviously have a lot of torque (usually around 1.5 to 2 hp) and vary on the voltage.
If this was coupled with a suitable speed controller, could anyone see a potential problem with using this type of motor?
Thanks.
COlin
