Hello:
Can someone please point me to the reasoning or theory behind the need for a water table for CNC pasma cutting?
Also, once I understand that need, which I assume is:
Slates of replaceable metal that provide enough (maxium) surface area behind a sheet of metal to "blow back."
Any reasoning behind the water? Do the slates of metal act as fin coolers?
If so, would I need to perform heat transfer calculations to find the ideal fin dimensions for maximum cooling?
My fin design is rusty, but I can dig it up once someone helps me understand the need of a water table or its purpose.
Thank you!
