586,077 active members*
4,035 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Low cost spindle ATC BT30 3kw 4 pole 220V 400hz max 600hz 18000rpm
Results 1 to 6 of 6
    Mar 2005
    305
    https://www.ebay.com/itm/183684947985
    more infomation please feel free to contact
    [email protected]
    849047985068 whatsapp
    thanks your visit
    Oct 2017
    49
    Re: Low cost spindle ATC BT30 3kw 4 pole 220V 400hz max 600hz 18000rpm
    Does it have encoder feedback?
    Mar 2005
    305
    Quote Originally Posted by jgwentworth96 View Post
    thanks your question
    it dont have encoder
    best regards
    15362
    Quote Originally Posted by tivoidethuong View Post
    [email protected]
    thanks your visit
    Looks good who is the manufacture
    Mactec54
    Mar 2005
    305
    customizer good in grinding spindle factory
    Mar 2005
    305
    i have 3 type spindle
    Spindle 3kw 220V pole 4 pole
    nominal voltage 220V rated frequency 400hz max 600hz
    Max rotation speed 18000rpm
    Water cooling
    Body diameter 100mm length 450mm weight 16kg
    BT30 grip clamp, pneumatic pressure release clamp 6kg / cm2
    3 bearing, front 2pcs 7007, back 1pcs 7005, all p4 china bearing
    Spindle 5.5kw 4 pole 380V
    nominal voltage 380V nominal frequency 400hz max 600hz
    Water cooling
    Body diameter 125mm length 500mm weight 25kg
    4 bearing, front 2pcs 7008, back 2pcs 7006, all p4 china bearing
    Spindle 5.5kw 4 pole 220V
    nominal voltage 220V nominal frequency 400hz max 600hz
    Water cooling
    Body diameter 125mm length 460mm weight 25kg
  1. Replies: 3
    Last Post: 01-28-2019, 07:22 PM
  2. Low cost atc spindle BT30
    By tivoidethuong in forum News Announcements
    Last Post: 12-20-2018, 09:17 AM
  3. Replies: 7
    Last Post: 03-22-2017, 03:48 AM
  4. Replies: 0
    Last Post: 06-26-2015, 03:51 AM
  5. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
