High Quality Laser Meter For Laser Tube Power Gauge
A Laser Power Meter consists of a display and a detector. The Laser Power Meters has been calibrated at a given wavelength before shipping.
1. Outline
Laser Power Meter using the amount of heat absorption measurement principle, thermal sensor measure the scope is very wide in spectral width and power, very high spatial uniformity, Without spot size, spot location or spot uneven impact. Can measure continuous wave laser output power, pulse repetition rate can also measure the average laser output power.
2. Technical parameters
Name Laser Power Meter
Model HLP-200
Range 0-200W
Display LED display
Minimum Resolution 0.1W
Photosensitive area 28mm
Spectral range 8-11um
Calibration Wavelength 10.6um
Response time ≤5S
Cooling Water-cooled
Application CO2 laser
Nonlinearity ±5%
Accept the surface
response nonuniformity ±5%
Consumption Power ≤8W
3. Advantage
Measure range 0-200w mini laser meter
1) Small size, easy to carry
2)Buit-in power supply, easy to use
3) Direct - reading, high - precision measurement
http://www.ebay.com/itm/Portable-pow...UAAOSwXYtYuDkp
