587,362 active members*
3,616 visitors online*
    Feb 2011
    36
    Moving a PCNC 1100
    Anyone have thoughts on moving an assembled PCNC 1100? If I put it on a flatbed trailer, would it survive an 1100 miles journey? Can it be secured enough without the straps putting too much stress where is doesn't belong?
    Anyone have experience moving one a long distance?
    Dave
    Jun 2008
    13
    When I asked Tormach the same question they cautioned that the tabs that the adjustable legs go through are not welded robust enough to handle much strain (ie bouncing along on a trailer).
    I'm sure some blocking would easily fix that problem though.
    John
    Jul 2007
    1602
    It isn't a lot of work to remove the machine from the stand so at a minimum do that. Also use a couple of straps and maybe some duct tape to hold the control panel door shut and unlock it. I hit a bump when moving mine and it broke the latch on the door lock. It wasn't expensive to replace but I had to order the part from Tormach.
    bob
    Mar 2010
    Moving Tormach 1100
    I just moved one 1000 miles on the back of a 3/4 ton truck with no problem.
    Placed a wood block between the spindle and table. Cross strapped to each
    corner across the head, and everything is fine. Did not disassemble anything.
    Oct 2009
    67
    I have a custom enclosure on mine and it would have been torn up by the turbulence of the highway. I rented a Budget Truck with lift gate and used a pallet jack. It was easy but loading was stressful. I had to take the Z-axis motor off, BTW.
  1. New Series 3 PCNC 1100
    By Wog in forum Tormach Personal CNC Mill
    Last Post: 04-23-2012, 08:51 PM
  2. PCNC 1100 help
    By jedge in forum Tormach Personal CNC Mill
    Last Post: 10-23-2010, 11:58 PM
  3. Rapid with PCNC 1100 and 770
    By concombrefrais in forum Tormach Personal CNC Mill
    Last Post: 10-12-2010, 10:56 AM
  4. For those of you with a PCNC 1100
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 01-02-2010, 12:51 AM
  5. What do you think of the New Tormack PCNC-1100
    By Willyb in forum Benchtop Machines
    Last Post: 03-20-2006, 04:31 PM
