587,213 active members*
3,872 visitors online*
Results 1 to 7 of 7
    Aug 2005
    62
    Any YAG experts around?
    I may get a used YAG-head really cheap.
    The laser is an Spectron Laser Systems and is marked "180W CW / 35mJ"
    I'ts just the head with engraving galvos and I'm wondering about the needed chiller and power supply data for a YAG of this size.
    I realize this is a major project to undertake so I need some more information. If I end up trying to get it going it won't be to make any profit from it, just for fun and learning!
    Regards
    /Daniel
    Oct 2007
    240
    The head itself is going to need some serious power... think in the range of 100A at a few tens of volts.
    Hi-TecDesigns.com -- Automotive Lighting Systems
    A CW yag laser uses arc lamps that run on anything from 180 to 340 volts at 40 to 80 AMPS
    plus the chiller used will need deionized water becouse the watter will be in contact with the lamp and Voltage terminals.
    you might get by using a ION laser PSU
    i can help you if you decide on taking the project.
    Eduardo
    Quote Originally Posted by dar303 View Post
    Regards
    /Daniel
    Oct 2007
    240
    Hmmm, I thought SLS used direct drive laser diodes in their systems, not flash lamps. If it's flash lamps, use Redsail's specs... if it's diodes, use mine.
    you are also correct, it could be diode pumped, but for the rated power i dont know.
    regards
    Eduardo
    Aug 2005
    62
    Aug 2005
    62
    Thanks for the offer Eduardo! I will know if I get the laser in about a week.
  1. ???? For The Gear Experts
    By Alex Westling in forum MetalWork Discussion
    Last Post: 02-02-2008, 04:42 AM
  2. Need Help from the experts
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 01-09-2008, 03:00 AM
  3. bearing experts i need your help?
    By MaxQ in forum MetalWork Discussion
    Last Post: 06-22-2007, 10:26 PM
  4. Any AB PLC experts?
    By jderou in forum CNC Machine Related Electronics
    Last Post: 11-12-2005, 02:14 AM
  5. any pic experts?
    By posix in forum PIC Programing / Design
    Last Post: 07-01-2005, 08:27 AM
