588,227 active members*
4,779 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Best Power Supply for the G540
Results 1 to 6 of 6
    Dec 2004
    1316
    I am planning to get a G540 for a router under construction. I am looking at two power supplies form keling and The KL-5020 seems good but based on the current draw the voltage drops significantly.
    http://www.kelinginc.net/KL-5020.pdf
    I was also looking at the KL-5413.
    http://www.kelinginc.net/KL_5413.pdf
    Can I use any of these two power supplies safely based on the lower voltages as the current draw increases?
    I was also thinking of pairing the G540 with either of these two motors, wiring them in series of course.
    http://www.homeshopcnc.com/RSstepperMotors2.html
    HomeshopCNC Nema 34 600 oz/in RS34-600
    or
    HomeshopCNC Nema 34 960 oz/in RS34-960
    Jason
    Jul 2007
    1602
    The rule of thumb for power supplies is 2/3 of the total amps. Since the G540 is rated at 3.5 amps per axis for a total of 14 amps you would at most need a 9.4 amp power supply of the appropriate voltage. If you are using 3 axes you can get by with a 7 amp supply.
    These motors are not optimal for use with the g540. Using the volts = 32 * SQRT(inductance) rule of thumb, the 600 oz/in motor wants 70V and the 960 oz/in motor wants 90v. You will actually get better performance from a smaller motor like the 318 or 387 oz/in motors from Keling. See this post by Mariss: http://www.cnczone.com/forums/showpo...0&postcount=11
    bob
    Dec 2004
    1316
    Thanks for the info Bob.
    I will consider the Vexta PK268-03A.
    Are there any nema 34 motors that were recommended by Mariss for the G540?
    Jason
    Apr 2008
    62
    The 400oz/in nema 34 stepper motors, wired in series, from Keling will work well with the G540.
    http://www.kelinginc.net/KL34H260-42-8A.pdf
    Timothy
    Dec 2004
    1316
    Thanks Timothy, I was trying to keep the inductance to a minimum, any thing less than 3mh.
    Jason
    Apr 2008
    62
    I guess the 6mh is a bit higher than you wanted. How about some 180oz/in steppers from Portescap?
    http://www.portescap.com/product-144-23H118D.html
    Timothy
  1. Gecko G540 Drive Power Supply
    By SSfab in forum Gecko Drives
    Last Post: 05-09-2013, 09:28 PM
  2. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  3. g540 and power supply
    By chrisw765 in forum Gecko Drives
    Last Post: 04-26-2009, 04:47 PM
  4. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
