![Quote](images/misc/quote_icon.png)
Originally Posted by
ihavenofish
so i set my router up to run under emc2. it solved an issue in mach3 that would cause it to stall in high speed contouring.
since im using the same pc to run the nm200, i figured id try emc on that too. i got it working briefly and then screwed up the settings somehow. i should have it back working today. for the moment it was running, it was doing 180ipm smoothly in all axes, so it looks promising for getting more reliable performance out of the mill than mach was doing.
i also noticed something about my machine. i dont use the limit swirches, so i took the Y axis switch and rail off. end to end the machine now has 27.875" travel in the X axis. y axis travel is 15.125" as its always been. not too shabby given the machine is advertised as 22x12 or some such. having nearly 28" in the x opens up some new possiblilities though.
once i get emc working again ill post the settings for configuring it if anyone else wants to try. it takes all of 1/2 an hour to set up.
the same settings should work on the nm145 as well, but as thats using its own pc and i havent had issues so far, im not going to be setting mine up on emc for now.
