I am playing with bob cad v21 and trying to program a ruffing cut and then a finish cut for my lathe i no how to make a ruffing cut and a finish cut
but i dont no how to do bolth of them in the same program ????
THanks
THanks
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Watching Sorin's video may help.
tobyaxis
do you want the bobcad file or the gcode program ???
Toby D.
Schwarzwald
I put the to the gcode and the cad file from bobcad i had to put .dxf so i can up load it just delete the .dxf at the end of the file
in the cad file i did a 0.050 ruffing cut then i moved the tool path up 0.030
and i used the drawing as the finish cut it dont work that good but it works
and i dont think it is the right way to do it
First thing first, on a Lathe all your X Coordinates should be Positive unless your machine is set up to machine in X-(minus).
Second, what is the Largest Diameter supposed to be?
Third, what Canned Cycles does this Control Support? G70-G76
Forth, this is not your average run off the Lathe part LOL, so what type of Tool Holders do you have, CNMG's, DNMG's, and a VNMG Profiling Tool?
This is need to know information for this type of part.
Toby D.
Schwarzwald
