Ok, so here she is! My next router.
You may notice similarities to the solsylva build, thats because I wanted to keep the ability to route oversize pieces. But the similarities stop there, and its fundamentally different in almost every way....its better!!
After a very interesting read in another thread about the best type of wood to use, it turns out I can't get most of the types that would be better (Such as Baltic Birch Plywood) locally, so Im still building from hardwood. But Im going to take Geof's advice, and build from mahogany instead of oak. Not sure about the viability of laminating it yet, but we'll see.
I made an animation in Google Sketchup to post in Google Video for you all to look at, but the commentary (By yours truly) didn't merge so I'll try again tomorrow.
Im using my adaptation of ger's rail design. Thanks for the idea ger :cheers: . This will use lengths of steel tubing bolted and glued into routed channels on my various rails. I attempted in the design to always have support on four sides. I managed this everywhere except in the up/down movement of the Z carriage, where instead, the opposite sides will be tightened outwards against each other to achieve stability.
Also I'll be using regular ABEC7 bearings. ( Shielded this time, unlike my solsylva build). This design uses a lot of bearings.....40 in the Z carriage, and another 32 between the two X rail runners.
I'm again using a laminate trimmer as my spindle, picking it up tomorrow because my other cheap Chinese one broke and I can't get a new collet nut....anyone know where I can get a collet nut for a 700W 'MacAllister' laminate trimmer? But the design makes it real easy to mount a larger router spindle simply by cutting new clamps. For now the trimmer will be fine because I dont want to go over the width of my Z carriage and cut down on my working area.
Working Area at this point I calculate at 28.2" Wide x 33.1" Long. But this may be slightly smaller/larger when I can measure the exact size of my spindle. I also think it is possible to adapt the design to get another 2" or so in width and length. I'll look into this over the next few days before construction starts. My Z movement will be around 6". This has to be confirmed tomorrow when I get measurements for my spindle.
I don't have a jointer, so to get the rails square I plan to measure thicknesses about every 4" along them with a caliper (Another item on order) and use lots of sandpaper. We'll see how this goes and how forgiving the design will be.
I have sent 8 emails to different companies requesting quotes for 16mm ballscrews and bearing mounts. Im hoping to buy from Marchant Dice or Reliance Machining. Reliance are more local and I talked to them on the phone already, but they cant machine my ends. But they are quite helpful. Marchant Dice and the other 6 companies on the other hand, haven't bothered replying to my e-mails (Or my pm).But anyway, they're probably just busy, its only been a few days. Ideally I'd like to buy from marchant dice since I picked suitable products from their site already. All thats left is for them to take my money....if they want it? (Hint Hint...reply to my message Marchant Dice....please....
Along with the laminate trimmer tomorrow Im picking up a nice new 2HP (Or 2.5Hp...I can't remember) router to use building this. The DeWalt 625. And last but not least a decent shop vacuum aswell. I dont have space for a proper extractor at the moment, but I need something on this build (Something...ANYTHING that sucks!!), the MDF dust was killing me with my solsylva machine.
The main aim of this build is to have a strong and solid machine at the end.
Loctite will be used on all fittings.
1/4" steel angle will be used in most places instead of 1/8" aluminium. (Thanks again to ger for that one.)
All joints will be bulky and reinforced somehow wherever possible (Thus the ends of the X beams are morticed into a groove in the end beams). Not many parts are less than 2" thick, and even fewer are less than 1". But I think I've hit a nice balance. I'm hoping that it'll be as solid as it looks without being too heavy. But if it ends up too heavy, I'll just get stronger motors.
Im using a dual leadscrew design, and am ordering the 4th Axis Upgrade Kit for my HCNC system. Im intending to slave one X Axis motor in Mach3 (Don't know how to do this yet!). Even with this system, I may need to go stronger than my 200oz/in motors. We shall see.....I have found up to 640oz/in steppers online that are rated at 3Amps (Max Amperage of my HCNC board), so if I need to upgrade the steppers I can do so without having to make an entirely new controller.
Im also ordering more stepper cable from HCNC, and Im going to either buy or make E-Chain to keep everything nice and tidy this time.
Limit switches are another item to be included.
The base is 1" MDF ( The only MDF Im using...uugh!), with square sections 6"x6" cut in it. This will reduce weight, and also allow me to make hold-down clamps which will fit under my surfaced sacrificial 2x1's.
Im intending to make my stepper mounts from my polymorph plastic. I'll make it into as close to rectangular as I can, then plane it flat and route a depression into it for the steppers. This will allow there to still be a more solid thick area around the stepper for the bolts. With my solsylva system I found that the approx 8mm thick stepper mounts were not rigid enough.
Im also going to make a perspex enclosure. this will be hinged on all four sides to allow it to fold away, and it has two hinged doors on the bottom ends to allow me to feed in oversize pieces.
Last but not least, when its finished and I've seen how the design works, if its fairly ok, I'll do up proper plans for it (Time dependant) and upload them for anyone who wants to build and/or improve on it. (Or build and burn it!)
Ok, so for now, there she is.....I await the most harsh judgement (Don't be too harsh...its my first design and took too long to start from scratch!) of my peers and those who know sooooo much more about this stuff than me. All comments are welcome, just keep it clean!![]()
