587,998 active members*
1,697 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Lathe Cycle Time In Predator
    Sep 2006
    296
    Ive searched the net and cant find a solution. The cycle time in Predator works great for mill work but is horribly inacurate on any lathe post i have found. Does anybody know the fix to get the cycle times at least close for a lathe in Predator backplot?
    Jun 2008
    1838
    Works fine here, just did a simple test cut of 50mm at 100mm/min and it showed 30 seconds, at 50mm/min it showed exactly 1 minute.
    Can you post a file for someone to run in their backplot, one that you know how long it should take ?
    If it works elsewhere then maybe you need to look at the "Machine" file you`re using ??
    Regards
    Rob
    :rainfro::rainfro:
    Dec 2008
    4548
    Quote Originally Posted by The Engine Guy View Post
    Regards
    Rob
    :rainfro::rainfro:
    Hi General,
    In a recent thread I help him with his post. It is fairly stripped down and missing alot of information. I got some stuff added that just got the cycle to start moving, but the inaccuracy may be due to other things missing. Since I dont know anything about a lathe, maybe you could take a look at his post processor and see if there is anything you would think should be added. My bet is it is a short in the post somewhere.
  1. run time cycle
    By mbmmachining in forum Mori Seiki lathes
    Last Post: 03-05-2010, 12:23 AM
  2. Cut off cycle time
    By Vern Smith in forum Haas Lathes
    Last Post: 07-10-2009, 06:05 AM
  3. cycle time
    By camtd in forum GibbsCAM
    Last Post: 12-30-2008, 05:20 PM
  4. NC Plot time cycle lathe wrong, answer
    By duenow in forum NCPlot G-Code editor / backplotter
    Last Post: 07-29-2007, 12:51 PM
  5. cycle time formula
    By cncsdr in forum MetalWork Discussion
    Last Post: 12-30-2005, 01:21 AM
