587,638 active members*
4,351 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Ugh, Bad Luck from Day One with G540
Results 1 to 16 of 16
    Dec 2006
    222
    Hi all; I got my GeckoDrive G540, 3 steppers, and power supply in the mail on Friday. I went ahead and set up an old machine with dual boot into Ubuntu so I could run EMC2 (trying to save money by not buying software and I prefer it's interface to Mach3.) I also snagged a "parallel data transfer" cable which is a printer cable with male connections on both sides.
    I wired up the power supply to an extension cord. I then attached pin 11 (on the gecko) to positive and 12 to negative on the power supply. I also ran 10 to negative to simulate an estop being connected. I configured EMC to send out the required charge pump signal on pin 16 (of the parallel port) and then fired everything up. Nothing happened except the "Fault" light on the Gecko stayed on. I double checked everything - it's all wired correctly. If I turn off the charge pump requirement on the gecko, Fault goes off, but I can't jog any axis or get anything to happen in either state. In short, only estop faked, computer plugged in, and power connected == fault.
    I then installed Mach 3 trial on the same machine (Vista 32bit) as I assumed it might be a Linux issue and used the Gecko G540 XML file - from the Gecko site - to configure it. Exact same behavior - Fault is always on unless I tell it ignore the charge pump.
    As best I can tell the Gecko and the computer are not talking. Is this the wrong printer cable? The use of a male DB25 on the Gecko is odd considering standard printer cables don't use a male connector on both ends. I'm worried this might be a null-modem style cable though it doesn't say it's a crossover on the packaging anywhere. Do you guys typically use an off the shelf cable and a gender changer?
    I have no reason to assume the parallel port doesn't work though I have no way to test it either. Windows sees the drivers installed correctly. Neither Mach3 nor EMC2 complained about the port in any way.
    Part of my buying the Gecko was to avoid the mess of a breakout board but I'm starting to wonder if that's the only way to figure out what's wrong. Is there any way to diagnose problems? The Gecko manual is a prime example of minimal information - it's only three pages and one of those is just a diagram. Here is it's section on the cable "PARALLEL PORT CABLE: Use a parallel port cable to connect the G540 to the PC. The G540 end of the cable must be a male DB25 connector." - Pretty enlightening.
    Anyways, pretty frustrated at this point because the red Fault light is taunting me. It wants me to know something is wrong but doesn't want to be helpful in any way.
    Any help or suggestions would be greatly appreciated, thanks!
    Mike
    P.S. I'm hoping it's the type of printer cable, going to be a problem if I have to use a different computer.
    Sep 2003
    126
    I hope you have a meter or access to one.
    Printer cable quick check: With a meter on ohms make sure you can read pin 1 to pin 1, pin 2 to pin 2, and so on with all pins of the cable. If 2 and 3 are swapped you have a null modem cable.
    I noticed the electronics forum here at CNC Zone has some posts relating to the G540 that might be able to help you.
    Jeff
    Sep 2003
    126
    Take a look at this thread.
    http://www.cnczone.com/forums/showthread.php?t=88240
    Jeff
    Feb 2006
    7063
    A "parallel transfer cable" is NOT the right cable to use! That is intended for LapLink and other PP to PP communications programs. It has many, many pins swapped. What you need is a 25-pin "straight-thru" cable - a simple printer extender cable.
    Regards,
    Ray L.
    Sep 2003
    126
    Good catch on the cable, I totally missed that in the first read.
    Dec 2006
    222
    I thought that might be the case - problem is that neither the manual nor the "initial setup" guide make it clear the type of cable one way or the other. And by using a female connector on the device itself rather than the expected standard printer male connector it gets even less clear what the intent might be - and it requires a gender changer for no good reason.
    Either way, at least it's an easy fix. Thanks much for the help everyone!
    Mike
    Feb 2006
    7063
    Quote Originally Posted by webgeek View Post
    Mike
    Any decent computer shop should have a male-to-male straight-thru cable. It's a very common cable.
    Regards,
    Ray L.
    Sep 2007
    200
    just in case its not the cable
    i happen to use a 540 with emc and
    i on top of the charge pump have to use
    1 as estop
    15 as probe in
    17 as amplifier enable
    Mar 2008
    3655
    Set the Parallel port to epp in computer bios.
    Here's an $8.95 proper cable that you can get pretty quick if you order it today:
    http://kelinginc.net/CNCPackage.html
    CR.
    Dec 2006
    222
    Quick update: it was just the cable. I switched to a different cable not twenty minutes ago and everything worked first try. Thanks much for all the help!
    One interesting thing to note - running tests in EMC2 produced much smoother motion than running them in Mach3. There were absolutely no "audible blips" when running many different tests in EMC2 but just jogging in Mach3 would occasionally "blip". Kind of interesting. Fortunately I was planning on using EMC2 either way so it's all good.
    Thanks again!
    Mike
    Feb 2006
    7063
    Thanks again!
    Mike
    That's because Linux is much better behaved than Windows, and it doesn't spend near as much time in the OS doing stupid "eye candy" things. Get a SmoothStepper, and you'll be amazed at how much smoother it can really be.
    Regards,
    Ray L.
    Feb 2007
    456
    Sounds like you need to optimize your Windows installation for running Mach.
    Jeff Birt
    Dec 2006
    222
    Or just use EMC2
    EMC is free and runs great so that seems good enough to me. I develop highly scalable software for a living so I'm not concerned about using Linux. I've already got it up on my network mounting my shared drives. I was surprised at how clean the Ubuntu UI is, I've not used a new X-client for a long time and they've come a long ways. Typically just do everything via an SSH connection.
    Thanks again for the help!
    Mike
    Jul 2003
    1759
    Plus you can do stuff like this
    http://electronicsam.com/images/Kand...nt4-26ghz1.png
    hint - look at task bar. No hickups.
    sam
    Or just use EMC2
    Mike
    Dec 2006
    222
    Now you're just showing off
    Jul 2003
    1759
    :devious: who me?
  1. Just my luck Sx3
    By Rainman229 in forum Syil Products
    Last Post: 09-23-2009, 06:16 AM
  2. just my luck Set up a coolant tank
    By Rainman229 in forum Shopmaster/Shoptask
    Last Post: 02-26-2009, 06:18 PM
  3. Bad Luck??? (long post)
    By Brad Morris in forum Mori Seiki Mills
    Last Post: 10-26-2008, 03:24 AM
  4. Pluto Servo - Any luck with EMC 2.2.2
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 01-05-2008, 05:09 PM
  5. has any one had luck with 0.6a steppers?
    By opusinwood in forum Stepper Motors / Drives
    Last Post: 06-06-2006, 02:06 PM
