588,265 active members*
9,719 visitors online*
Page 1 of 2 12
Results 1 to 20 of 35
    Jul 2009
    147
    Bellvill washers
    How much pressure is on the Bellvill washers in the PDB?
    How far are they compressed?
    Don't Panic!
    Mar 2009
    1863
    The manual says to tighten your draw bar finget tight or until the collet holds a TTS Tool Holder, then go two more turns. I went 2 1/2, and I have virtually no slippage.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Oct 2011
    477
    I tighten mine until the PDB will not release the tool and slowly back off until the tool will release. I try to do this with the pressure dropping to the compressor start pressure.
    As soon as time allows I intend to pipe this into my 80gal shop compressor. Usinf this system there should be virtually no pressure sag in operation.
    nitewatchman
    Jan 2013
    263
    Quote Originally Posted by davidperry3 View Post
    I'm curious to know this as well. You thinking about making your own belleville tensioned system with a manual release lever?
    Sep 2012
    1543
    Re: Bellvill washers
    I'm way past 2.5 turns, but I have a different drawbar for ATC I believe. My Tormach came with 3 drawbars, all different lengths if I remember right.
    Jul 2009
    147
    Quote Originally Posted by GJeff View Post
    Bingo!
    It cant be that hard.
    Don't Panic!
    Feb 2006
    7063
    Properly retaining TTS tooling requires upwards of 2500# of drawbar tension, which means your release mechanism needs to be capable of well over 3000#. Even the Tormach PDB seems to suffer from pull-out, judging from the number of problems cited here over the last several months. My solution is a motor-driven drawbar, driving through a high ratio (50:1) planetary gearbox. This allows me to properly, and very consistently, torque the drawbar to 25 ft-lbs, and has the added advantage of allowing me to use R8 tools just as easily as TTS tools. This system has worked flawlessly for me, for the last year.
    Regards,
    Ray L.
    Sep 2012
    1543
    Torque? So your spinning the drawbar?
    Jul 2009
    147
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    I am currently using an air ratchet, it works great and I have never had pull out. Still a simple lever that compresses spring washers would be even faster. The little bit of research I have done says you can stack as many of these washers as you need for the force required. If you need more travel you can invert some of them in the stack. It would seem to me that the travel you would need would be slight to get the collet to release.
    Don't Panic!
    Jan 2007
    1332
    For someone who has never seen a Tormach or Tormach PDB, the use of the words "seems to suffer from" is appropriate.
    Feb 2006
    7063
    Quote Originally Posted by BAMCNC.COM View Post
    Yes, I spin the stock drawbar. With my current PDB, driven by a 400 oz-in stepper motor, I have more than enough torque on-tap (~100 ft-lbs) to easily twist the drawbar completely off. I have it set to about 25 ft-lbs when tightening, about 35 ft-lbs when loosening. As I said, it has worked absolutely flawlessly since the first day I put it into service about a year ago. No pull-out, ever, even on the most aggressive cuts.
    Regards,
    Ray L.
    Jan 2013
    263
    Looks like there are far fewer washers on the actual Tormach one:
    Appears to be 8 in a ()()()() configuration but an actual owner should be able to tell you. Wouldn't be very much travel required for the lever especially since they're already partially compressed before you compress them further to release the tool. Each washer's full range of compression at that size is probably no more than 0.050 using LeeSpring.com as a reference. So you're talking 0.4" maximum travel, realistically you only need to move <0.2" (if that) at 3000 lbs which seems very do-able.
    Apr 2006
    439
    Hey David
    I am sure you are aware of my Manual Drawbar http://www.sdmfabricating.com/LOD.html I use 12 Bellevilles and compress them quite a bit, they pull on the drawbar with about 2600 lbs. This is about equal to tightening the stock drawbar to about 35 ft lb. When it is all loaded up it only needs about .035" travel to release a tool from the collet. The amout of distance your preload requires is strictly dependent on the type and number of Bellevilles you use.
    Scott
    Jul 2009
    147
    Quote Originally Posted by Scott_M View Post
    Hey David
    Scott
    Yours is what got me thinking. I thought I might take a crack at the design and see if I could figure a way around modifing the motor base casting.
    Don't Panic!
    Feb 2006
    7063
    Why would you need to modify the casting for ANY PDB, beyond finding/making two threaded holes to hold it in place? I've build PDBs using impact wrenches, Belleville springs, and various kinds of motor, and never needed anything more than two threaded holes, which can be located almost anywhere. The PDB should not be heavy, and should not be transmitting a large force through its attachment points.
    Regards,
    Ray L.
    Jul 2009
    147
    Regards,
    Ray L.
    Can you post one of your spring washer DB designs?
    Don't Panic!
    Feb 2006
    7063
    Not really. That was years ago, and I don't have any decent pictures of it.
    Scott's is by far the most elegant Belleville design I've ever seen. If I were to go that route again, I'd do it very much like he did.
    Regards,
    Ray L.
    Jul 2009
    147
    Regards,
    Ray L.
    Which requires modifying the casting.
    Don't Panic!
    Feb 2006
    7063
    I think you don't understand how Scotts PDB works.... The "magic" all happens in the piece that mounts directly to the spindle. The rest you can replace with a small-ish air cylinder (or even a linear actuator), and there is not a lot of force involved in that part of it, so you can likely use existing bolt holes for mounting the air cylinder. Even with his "manual" setup, the only "modifications" to the casting is drilling a few holes for mounting bolts.
    Regards,
    Ray L.
    Jul 2007
    1602
    How many washers are you guys using on your PDB? Mine came with 6 but I see pictures where they are using 8. I know mine drags a bit when removing the holder so perhaps the 8 washer configuration is to make life easier for the tool changer?
    bob
Page 1 of 2 12
  1. bellville washers
    By fsmith61 in forum Toyoda
    Last Post: 04-12-2014, 09:29 PM
  2. Vibratory Polishing Washers...?
    By tof1 in forum Mass finishing equipment/media/strategies
    Last Post: 07-20-2008, 12:48 AM
  3. RFQ: Aluminum Washers
    By kellogs72 in forum Employment Opportunity
    Last Post: 12-25-2005, 04:48 AM
  4. machining washers
    By MBG in forum MetalWork Discussion
    Last Post: 03-10-2005, 08:44 PM
  5. RFQ: Washers
    Last Post: 02-21-2005, 01:00 PM
