588,648 active members*
6,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3 CNC Fusion kit with upgraded bearings?
    May 2005
    6
    The CNC Fusion ballscrew CNC conversion looks compelling, though I've heard many comments that using the X3's stock bearings is insufficient. For those who have experience with the kit, would it be possible to upgrade to angular contact bearings in a straightforward manner? Is there a simple part-replacement solution (ie: improved bearings that would fit the existing bores) out there?
    Thanks.
    Oct 2006
    57
    I have searched for high quality AC bearings of the same size and so far not found any that would fit. I do not claim I have made an exhaustive search.
    The ISO model number for the standard 3 piece thrust ball bearings is:
    51101 and the dimensions are:
    OD:26mm
    W:9 mm
    My understanding about fit for AC bearings is as follows:
    ID - must be absolutely right
    OD - must be very, very close to right
    Depth - you can easily get away with bearings of lesser width (meaning depth of pocket) as long as your mechanism to tighten (load) fits inside the pocket (high tolerance spacers apparently work). It has been suggested to me that having a bearing marginally too wide (say a 10mm width bearing in a 9mm pocket) would also be OK.
    So far, all the "good" (expensive) AC bearings I have found with a 12mm ID are too big in OD which would require machining the diameter of the pocket larger.
    If you find any please post your results!
    Regards,
    George
    Mar 2008
    3655
    The CNC Fusion Deluxe X3 kit now comes with AC bearings for X and Y axes.
    CR.
  1. Upgraded postprocessors
    By Alan L in forum Hypermill
    Last Post: 01-03-2007, 06:22 PM
  2. My upgraded machine and cabinet
    By Parameter in forum CNC Wood Router Project Log
    Last Post: 11-22-2005, 08:51 PM
  3. Upgraded to 4.0, now only X axis works??
    By Mueller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2005, 04:23 PM
  4. We upgraded to 2005.
    By duluthboat in forum FeatureCAM CAD/CAM
    Last Post: 05-01-2005, 03:41 PM
  5. Well I upgraded to XP pro
    By WallCrawler in forum Computers / Desktops / Networking
    Last Post: 02-23-2004, 10:54 PM
