588,672 active members*
6,363 visitors online*
    Mar 2005
    73
    T2 Parameter Problem? Help!
    I just bought and took delivery of a QT-15 with a T2 that was supposed to be 100% ready to plug and play... Well it's not. powered up and all the parameters had been lost, re entered them by hand from the list provided with documentation after powering on and charging all the batteries. Now for the fun part, everything works great except...... I wrote a simple face turn program for a 2.00 diameter bar to be turned to 1.00, when you hit cycle start the tool travels across centerline to -2.00 and faces to 0, then the tool travels across centerline to -2.00 and turns the stock down to -1.00 then goes home. At this point I'm cutting air so of course this would not work with an actual workpiece in the chuck. Simulation shows the turret coming from the bottom of the screen instead of the top like my other QT-15 with a T2 does. Any ideas??????
    "Fire is cool" -Beavis
    Mar 2005
    73
    Bump
    May 2012
    Since you have 2 QT-15s I would comare parameters. Maybe something will stand out. Do you have a T2 parameter manual?
  1. fanuc 6t parameter problem
    By moghul in forum Fanuc
    Last Post: 12-30-2011, 07:59 PM
  2. Fanuc OM ATC parameter problem
    By techscan in forum Fanuc
    Last Post: 09-18-2011, 04:49 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Machine parameter problem ...
    By talash in forum DNC Problems and Solutions
    Last Post: 10-09-2008, 10:20 AM
  5. Miyano parameter Problem
    By AFX in forum Fanuc
    Last Post: 02-01-2007, 08:28 AM
