Axis Slow Down
I’m running the 3 axis Xylotex with the 270oz motors (got the kit from them with the 24v power supply) with Mach 3. I've started having an odd thing happen to my cnc machine, if I run a big job about 30 minutes into it my motors seem to lock up. They make a knocking sound and just sit there. If I stop the job and then try and jog an axis at first it seems like nothing is happening but if you just hold down the key you can hear the motor starting to move, the longer you hold the key down the quicker the motor starts to move. But when I say move I mean like .001 per second. The other odd bit is if I close Mach 3 and start it back up everything works normal.
At first I thought it might an over heating issue so I changed it so the fan it’s actually on top of the heat sinks. Then I thought it’s a software problem so I fired Mach 2 back up and the same thing still happens. The next step was I swapped out the computer and it still does the same thing. I’ve also tried running a few different big jobs and it locks up on them too.
I hadn’t changed anything and everything was working fine, this just sprang up. So anyone got any ideas what’s going on?
Just a note: when this happens nothing feels hot. The heat sinks are pretty much cool, the power supply is just warm and the motors are warm like they normally are.
Take it easy.
Jay (www.cncjay.com)
