586,617 active members*
2,463 visitors online*
IndustryArena Forum > CAM Software > Vectric > Corian Color Lithophane Lamp!
Results 1 to 16 of 16
    Sep 2005
    116
    Try saying that fast 5 times!
    I made the entire lamp out of 1/4 inch Corian and cut the Litho with a 45 degree V-bit. In PhotoVCarve I set it up as a 0.03 ball nose bit with max depth at 0.15" and line spacing at 16%. I set Z-zero at -0.05, with the max depth at 0.15" I got more of a 3D effect than I would have at 0.1". I used a 23watt fluorescent light bulb and an outdoor light fixture.
    Attached Thumbnails Attached Thumbnails Web_Backlight.jpg   Web_Backlight2.jpg   Web_BackSide.jpg   Web_Top2.jpg
    Mar 2005
    35
    Very nice!
    Thats a cool effect. What did you use for color and how did you apply it? Good stuff!
    Oct 2005
    672
    That's pretty neat. What adhesive/glue are you using on the Corian?
    Sep 2005
    116
    A six minute epoxy. After a little research I discovered that Corian glue is simply a color matched epoxy glue.
    Apr 2005
    3634
    Great job!
    I would like to know how you added the colors.
    Did you paint the inside of the box (behind the photo carve)?
    Free DXF - vectorink.com
    Apr 2005
    3634
    Another idea, that I think would look good with that carving, would be to use LED lights & make the box very thin, then it could be put on a picture frame stand.
    Kinda like this here (only light from behind, like you did).
    Sep 2005
    116
    I used HP color transparency film.
    1st I converted the full color image into a CMYK image and then deleted the "K" channel which is the black or shades of gray that the lithophane already represents.
    Then glue the transparency to the back of the lithophane being sure to line it up just right. I used 3M's 77 spray adhesive.
    I then gave it a light coat of mat white lacquer paint over the transparency so that the color "magically" disappears when the light is turned off...:rainfro:
    Apr 2009
    Quote Originally Posted by bsimages View Post
    Just joined the site, awesome information on here. I was just curious how do you convert the photo to the CMYK? Is it done in photoshop? or are there other programs available to do this?
    thanks and awesome litho,
    matt
    Sep 2005
    116
    I did it in Photoshop, though I am sure there are many other photo editing programs that would do it just fine. Including some shareware programs.
    Is your machine homemade? Mine is.
    Have you got your copy of PhotoVcarve yet? It is well worth the cost in my opinion!
    WARNING!
    Lithophanes ARE addictive, and habit forming!
    I make a lot nightlight lithophanes myself.
    Bill
    Apr 2009
    I have a small desktop system on order but I am also building a larger one for myself but only in design stages. I saw a lithophane at school a few years ago and have wanted to make them ever since. Im starting a small business making them this summer.
    Im curious about the V-bits you use? from black and decker right? do you know where i can buy them? or others as I have a feeling the ballnose bits will become expensive very quickly.
    Thanks,
    Matt
    v-carve order next week, cant wait
    Sep 2005
    116
    Vermont American also makes a double 1/4 V-bit 45/60 degree #22109.
    Any V-bit will work fine. After you get the software I would be happy help you with the software settings.
    Bill
    Apr 2004
    175
    Nice work Bill, as always, your work is impecable...
    Chuck
    Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
    Mar 2009
    3
    OK, I have a trial version of Photoshop 7 on my machine.
    How the heck do you convert an image to CYMK and remove K?
    35538
    Image>Mode>CMYK
    Then, in the layer thing in the bottom right, click on the channel tab, then you can right click on the one you want to delete.
    Mar 2009
    3
    I don't see CMYK under Image/Mode.
    All I see is Bitmap, Grayscale, Indexed Color and RGB color.
    Sep 2005
    116
    Quote Originally Posted by BruceHanson View Post
    What is the image? Try converting it to RGB then try again and see if CMYK appears as an option.
    Bill
  1. My 1st Lithophane...
    By bsimages in forum Vectric
    Last Post: 12-28-2013, 06:53 PM
  2. A lithophane without a roughing toolpath on 1/4" corian!?!
    By bsimages in forum PhotoVCarve and VCarve Pro
    Last Post: 06-07-2011, 12:56 AM
  3. GE 388 Lamp
    By lgreeves in forum Fanuc
    Last Post: 02-01-2010, 08:20 PM
  4. Fanuc 15-M... Spindle Off lamp stays ON
    By cncnovice in forum Haas Mills
    Last Post: 05-11-2006, 03:04 PM
  5. Neon indicator lamp question
    By The Wizard in forum CNC Machine Related Electronics
    Last Post: 05-01-2005, 04:28 PM
