588,662 active members*
5,139 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Cutting 3/8 plywood, which bits.
    Sep 2011
    26
    I have a solsylva machine I just finished building. My goal is to cut shapes out of the 3/8" or 1/2" plywood, say 2"x4" area. However I need to leave a lip around the whole way around the outside. So the first cut would be 1/8" down around the radius of the shape. Then the next cut would be through the whole sheet.
    Hopefully this makes sense. The router is 30000 rpm, 5.6amp.
    So my questions:
    1. Can the router make this cut on a single pass? Feedrate etc?
    2. Which Bits would be the best choice.
    Depends on how rigid your machine is. Plus, you just said you needed two passes?
    If you want to cut 3/8" in a single pass, I'd use a 3/8" diameter bit or bigger.
    My question is how will you hold such small parts?
    Feedrate etc?
    30,000 rpm is much too high. If you can't lower it, you can cut as fast as your machine is capable of.
    I'd probably use a downcut 2 flute spiral
    Sep 2011
    26
    The pieces will be cut out of a sheet. So i just have to hold the sheet. The lip needed is on the inside of the sheet.
    I realize i need two passes haha, but i mean one pass for the lip and one to cut the inside.
  1. Cutting .25 in plywood
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-27-2012, 09:09 AM
  2. cutting plywood w/ a laser
    By sthole in forum WoodWorking Topics
    Last Post: 09-13-2011, 09:38 AM
  3. Feeds, speeds, and bits for plywood
    By sploo in forum WoodWorking Topics
    Last Post: 09-17-2007, 05:59 PM
  4. Sizing of CNC Machines For plywood cutting
    By dswink in forum DIY CNC Router Table Machines
    Last Post: 05-17-2007, 08:50 AM
  5. What Bits Do You use For Plywood?
    By Joe Petro in forum DIY CNC Router Table Machines
    Last Post: 02-24-2006, 09:07 PM
