588,225 active members*
4,800 visitors online*
    May 2005
    160
    shaft couplers
    where are you guys getting the shaft couplers ive seen some really nice ones on here for doing a direct drive with steppers on bench mills.
    kinda would like to know the brand im having a hard time finding them in the msc book. the ones ive seen look really heavy duty
    Cool
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Apr 2005
    1778
    dgalaxy,
    I bought the "Lovejoy" couplers from MSC. I found them on pages 3860, 3861. I was connecting a 3/8" shaft to a 1/4" shaft. The part numbers and prices are below (late 2005).
    item # your price
    35407014 $2.19 ea
    Product Description: Three Piece Jaw Couplings Type: Three Piece Jaw Coupling Style: Coupling Hub Maximum Bore Diameter: 3/8 Outside Diameter: 1.08 In. Overall Length: 1.72 In. Material: Plastic
    35407097 $1.44 ea
    Product Description: BUNA-N SPIDER/L050 HUB L050 JAW SPIDER COUPLING
    35407006 $2.19 ea
    Product Description: Three Piece Jaw Couplings Type: Three Piece Jaw Coupling Style: Coupling Hub Maximum Bore Diameter: 1/4 Outside Diameter: 1.08 In. Overall Length: 1.72 In. Material: Plastic
    If you search by part number it will get you to the right page. Each coupler requires two sets of jaws and 1 spider. You can mix and match shaft sizes within the same series.
    Good luck,
    Alan
    May 2005
    160
    Thanks So much
    Aug 2005
    437
    I use McMaster-Carr (www.mcmaster.com) They have almost every thing. Do a search for "couplings" .
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
