I have a plywood item with 1200*1200 size , and I want to cut it using my Nova 63 with 1600*1000 work table.
So as you see, the width of work table smaller than the item, but I can put the item to the table without front panels with honey table.
I am already cutting 1500*1500 items without front panels using broaching openings, but only for 1600*1000 work table.
May be there is a procedure for broaching of fabric roll that I can use for my case?
Is there a procedure in order to cut it right ? Perhaps using laser red dot and dot scan of first point?
Should I сut the drawing in two pieces with this procedure?
Thanks in advance.
