588,638 active members*
5,594 visitors online*
    Sep 2005
    221
    macro's for probing?
    Would anyone care to share probing macros for a fanuc 18i control, or similar?
    Or maybe point to where they can be found?
    Thanks!
    Mar 2005
    988
    That's too broad of a question for probing macros. It depends on your probe make/model, machine, machine control, mill/lathe, mill/turn, variables used by machine builder, etc.
    Are you adding a probe or looking for more subs on existing? Generally, going back to the builder is the best if you're missing them...
    It's just a part..... cutter still goes round and round....
    Jun 2008
    Actually, the probe is an accurate switch that send a on or off signal to CNC controller when the stylus was contacted (trigger) the component. There are two kinds of function that use measured both tool's length and diameter,which is put on the table of machine tool or set up a pull down arm beside spindle head in the lathe, is called tool setting and use measured the parts of features, which is set in spindle head or lathe's turret, is called inspection probe. For Fanuc or Meldas controller, all moving command is used G31 (skip function) when it received the signal from probe trigger. The machine was stopped moving immediately. For example: The parts of inspected program,
    O3000
    G90G80G40
    POPEN
    (Probing Cycle Start)
    G55
    G43Z30.H90F2000.(Edit Z coordinate in this block)
    #31= #[2000 +#4111](Length of active tool)
    (Two Touch Probing)
    G31X0 Y0 Z-10.0 F2000.
    G01X[0+#5061]Y[0+#5062]Z[0+#5063-#31]F2000.
    G04P3
    G31X0. Y0.Z-10.0 F30.
    G01X[0.000-#502]Y[0.000-#503]Z-10.0 F2000.
    #3004=0
    (Output measured data)
    #100=[#5061+#502]
    #101=[#5062+#503]
    #102=[#5063-#31+#501]
    DPRNT[X#100[53]*Y#101[53]*Z#102[53]]
    ( End of touch move 1)
    PCLOS
    M30
  1. Digitizing macro's
    By pants in forum Digitizing and Laser Digitizing
    Last Post: 01-16-2009, 09:07 PM
  2. Macro's on Fanuc OT
    By pinguS in forum Fanuc
    Last Post: 09-23-2006, 10:51 PM
  3. Macro's for the masses
    By Equinox in forum G-Code Programing
    Last Post: 06-22-2006, 07:47 AM
  4. macro's
    By Traceycnc300 in forum Haas Mills
    Last Post: 04-17-2006, 06:43 PM
  5. How to use Macro's
    By smallplanes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2005, 10:32 AM
