Hi all,
Till now i use a EaziCNC M640 controller which has it all. But when i program a speed of, let's say 20mm/sec: straight lines maintain this speed but when it comes to curves or circles it reduces down to practicaly zero!! This does burn the material at that place and the mill.
I think of replacing this controller but i can't find what... Things i really want this controller to do or have:
- serial (RS232) or USB input
- Manual feedrate overide (potentiometer or encoder)
- up to 4 outputs for stepper-drivers (step/direction 5V TTL)
- maintain programmed mill travelspeed on every move (circular or straight)
- input for optical encoders from steppermotors (512 cpr balanced outputs)
- emergency stop (NO/NC available)
- G-Code
- simple manual control input (just switches preferred)
- with program to set all parameters
- 12V/5V supply preferred
- small
- not too expensive
Any suggestions??
