I'm cutting inlay for guitars and I cut some out of mother of pearl about 3 months ago and now just cut the fingerboard and the pieces don't fit. They basically are too perfect. I've cut this same program before and they fit perfect, but then again when I installed then I was using epoxy so maybe that helped lube up the pockets and they slipped in. Now I'm dry fitting them and then using super thin cyano to glue them in, but some pieces are too tight. All the abalone and gold mother of pearl fits but the regular white mother of pearl doesn't. I don't think my machine got more accurate but you never know.
Anyway after that long diatribe I was wondering if there was a way to tell artcam when I'm using the inlay function to cut the male parts to take off a little extra material, probably something like .002". Any suggestions, I could always just trick it by saying I'm using a .0136" bit instead of the .0156" bit, but I'm not sure if this will mess up other things as I know it makes the paths with the inlay function based on the counterpart using the same size bits.
