Hi, I want to put a small VMC in my basement so I can learn and play. Is that realistic? cosidering coolant, noise, power. I will be milling Aluminum 99% of the time. I do have a big and 10' ceiling unfurnished basement.
A small VMC.
I don't know how many axis I want. I figure if I use 3 axis, I have to turn the part manually because I have milling on at least 4 sides. It is a box shaped part). 4"x4"x4", I need to cut the inside out and leave .1" edge. But the edge will not be evenly 0.1", it will have some complex shapes. Is it worthwhile to go 4 or 5 axis?
Is there a conversion process I can do to transfer pro-E file directly to machine code that the VMC understand? So it can figure out the tooling and cutting automatically? Is that different for different brand VMC?
thanks
-Andrew
