588,665 active members*
5,150 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need 19mm ID x 20mm OD brass tubing
    Jan 2012
    Anyone know where I can get 30 inch lengths of 19mm ID x 20mm OD brass tubing?
    Apr 2006
    3206
    Jan 2012
    Thanks for the link. It looks promising.
  1. Drilling 2mm holes through 19mm bolt heads in 316L
    By SQT18MS in forum MetalWork Discussion
    Last Post: 01-25-2016, 07:40 PM
  2. What is the best way to cut thin wall brass tubing?
    By lerman in forum MetalWork Discussion
    Last Post: 08-11-2015, 03:47 AM
  3. Feeds and Speeds for Brass tubing
    By acliffhay in forum Tormach Personal CNC Mill
    Last Post: 09-17-2010, 02:09 AM
  4. milling Telescoping brass tubing
    By jackie_burton@m in forum MetalWork Discussion
    Last Post: 10-05-2008, 08:45 AM
  5. milling thin wall brass tubing
    By jackie_burton@m in forum Material Machining Solutions
    Last Post: 09-29-2008, 09:46 PM
