588,309 active members*
4,533 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Closed loop with Delta C2000 and 12000rpm 400hz spindle
    Dec 2006
    112
    Hello,
    I´m trying to get a 12000rpm spindle to work in closed loop with a Delta C2000 with option card for incremental encoder but for some reason it wont spin up to more than 6hz for a while and then it overloads.
    I have tried first a chinese inverter and now the Delta C2000 and the same accurs on both of them.
    The spindle is a chinese ATC water cooled ATC spindle, rated 6000rpm 200hz, max 12000rpm 400hz.
    Encoder 1024ppr differential ABZ signals.
    The encoder seem to count up fine on the inverter display and one lap corresponds to 4096 pulses.
    Any ideas?
    Dec 2006
    112
    Re: Closed loop with Delta C2000 and 12000rpm 400hz spindle
    Now its working in speed mode at least but the positioning seem to be harder to get working.
  1. Closed loop spindle controll VFD with m5i20
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 10-07-2012, 06:29 PM
  2. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  3. Closed Loop Vector Drive for Spindle Motor
    By vishnu in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2011, 11:22 AM
  4. can any AC spindle motor be used with closed loop velocity control?
    By Mike Braddock in forum Servo Motors / Drives
    Last Post: 09-10-2008, 02:40 AM
  5. Closed Loop Driver vs. Closed Loop Computer
    By ojibberish in forum Gecko Drives
    Last Post: 06-08-2004, 05:30 PM
