Hello, I am new to this forum and new to the CNC world. I recently purchased a MultiCam 1000 and I am having an issue with the 3/8" solid carbide compression cutter. The cutter works fine however during the entry and exist into the sheet, it produces a chip on the top surface which is unacceptable. Could this be due to the fact that I have it set up to enter and exist on an incline? Would a straight plunge in produce zero chip out, or should I use a different cutter? Any help would be great....thanks
