588,348 active members*
6,079 visitors online*
    Apr 2006
    24
    oz-calculation help needed
    At the bottom of the second table at http://www.cnsoyo.com/cp_1_8_e.asp they state that SY57STH76-2804MA has 18.9 kg-cm torque.
    Would that be ~1700 oz/inch or have i messed up as usual ?
    I was following this formula:
    120g/cm into oz/in?
    1 gram = 0.0352739619 ounce
    1 centimeter = 0.393700787 inch
    Now using algebra we find that:
    1 gram/centimeter = (0.0352739619/0.393700787) ounce/inch
    1 gram/centimeter = 0.0895958634 ounce/inch
    120 * 0.0895958634 = 10.751503608 ounce/inch
    /Ulf
    Dec 2006
    242
    Torque is the multiplication of a force * a distance (lever arm). You are dividing. I am sure somewhere along the way, you saw someone write torque as ft/lb or lb/in, but that was in error. If the kg * cm unit is kg force, then a kg*cm is 2.205 lb*cm because 1kg = 2.205 lbs. Further, 1 cm =.3937 inches. So, 1 kg*cm = 2.205 lb *.3937 inches = .8681 inch lbs. So, 18.9 kg*cm = 16.41 inch lbs. To convert to ounces, 16 ounces = 1 lb, so 16.41 inch lbs = 262.6 inch ounces. Good thing you asked, eh?
    Apr 2006
    24
    thankx mate... then those are to good for the proxxon MF70 im buying
    just to check the other motors then
    /Ulf
    Jun 2003
    3312
    1 kg-cm = 13.887 Oz-in. 262ozin is correct.
    http://www.pminmo.com/wiki/index.php?title=TorqueUnits
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  1. Back EMF calculation?
    By OCNC in forum Stepper Motors / Drives
    Last Post: 05-28-2014, 02:41 PM
  2. Calculation of ramp angle
    By mrk in forum Coding
    Last Post: 04-22-2011, 03:21 AM
  3. Is this calculation correct?
    By h3ndrix in forum Stepper Motors / Drives
    Last Post: 02-07-2006, 07:08 AM
  4. Deflection calculation software
    By bdrmachine in forum Bending, Forging, Extrusion...
    Last Post: 09-21-2005, 02:01 AM
  5. resistor calculation need help
    By mike10 in forum Stepper Motors / Drives
    Last Post: 03-30-2005, 04:21 AM
