madaouk,
For determining machining speeds and feeds I trust Machinist Mate software. Assuming your 0.8mm cutter (0.032" in my familiar units) is carbide, MM reccomends 47746 rpm and 10.7ipm (272mm/min) based on chip loading. My machining of brass and nickel silver with a 0.5mm cutter, slowing the cutting speed in ratio to the 20000 maximum RPM of the Proxxon spindle, seems to bear out the suitability of the MM reccomendations (I haven't broken a cutter
If you are already getting 400ipm it sounds to me that you are doing very well...
Best regards,
Randy
