588,540 active members*
4,934 visitors online*
Page 1 of 3 123
Results 1 to 20 of 55
    Dec 2012
    First machine build after 5 year break (pics)
    Hello all,
    I started this machine about 6 years ago and then life hapened!
    I knew then where I was going with it however after a five years away from it I can't remember a dang thing!
    I am not sure where to be posting this, as this is my first post. I built this mchine as a lurker, reading and gathering info on the web however I lost that old computer that had everything stored on it.
    So I am starting from scratch and am hoping to share progress pics, I know I am going to need your help as I go !!!!!
    The screws are acme 1/2 8 double starts and the nuts are a spring compressed nylon assembly forgot where they came from... the steppers are tormach 640 oz. I remember I was planning on geko drivers? and now I am getting lost and wondering .....
    I have a lot of the mechanicals to finish and will post pics as I go, I did a lot of lost foam casting early on in this build, hopefully I can complete this machine without to much more of that!!!!
    Thank you so much Tom
    Attached Thumbnails Attached Thumbnails 014 copy.jpg   016 copy.jpg   021 copy.jpg
    Dec 2012
    some more pics
    A few more pics....
    Thanks again tom
    Dec 2012
    some more pics
    Thanks all
    Attached Thumbnails Attached Thumbnails 012 copy.jpg   015 copy.jpg   023 copy.jpg
    Apr 2007
    8082
    The anti-backlash lead screw nuts look like they came from DumpsterCNC.com. I've used them on two machine builds with no issues at all.
    This is the right place to post this. Welcome back to CNC building.
    CarveOne
    http://www.carveonecncwoodcraft.com
    Dec 2012
    Thank you carve one
    Hello all,
    Had some time this week and have been working on getting the motor mounted for the y axis . My machine is similar to many others however my use of 1 3/4" tubing to tie the side rails together created some different design problems.
    I intend to use one motor to drive 2 screws, while this is not the simplest aproach for a machine I hope ultimately it will work.
    Carve one thanks for jogging my memory, and thoughtfully posting on my build!
    Pics included
    I welcome all you talented peoples input!
    Tom
    Dec 2012
    Poor mans tapping fixture
    I converted an old drill press into a hand tapping fixture to keep my threading accurate
    Tom
    Jul 2008
    390
    Once you CNC you can't go back. Your return was inevitable.
    Dec 2012
    Here are some pics of the bearing suports for the y axis , these will suport the timing pulleys at each end of the table wich will in turn be driven by the centrally located motor
    Tanks for looking
    Dec 2012
    HOME BUILT BANDSAW
    Hello again,
    Here is a pic of my home built vertical bansaw , been using it a lot for this build.
    thanks for looking
    May 2007
    119
    nice job on the saw
    Dec 2012
    Thanks Kevin
    Apr 2009
    5516
    Looking good! Great job on the bandsaw asd drill press as well!
    Dec 2012
    Thanks louie,
    It's nice to know people are looking.
    Apr 2007
    1955
    You would be amazed at how many people take a look. I learn from every single project and picture people post, perhaps the most from the "rework".
    I am starting to think about my multi year project again as well.
    Dec 2012
    MORE PROGRESS PICS
    Hello all,
    A few more pics of the progress I have made in the last few days.
    I have a question ; I will soon be done with the mehanics of this build and will need help with the electronics portion where do I post those questions?
    Thanks, Tom
    Attached Thumbnails Attached Thumbnails 001 copy.jpg   002 copy.jpg   003 copy.jpg   006.jpg
    Dec 2012
    another pic or two
    Some mor pics,
    Have one side done , now have to install all the other parts on the other side!
    First side was fun second side is feeling like work! :violin::violin:
    Dec 2012
    One more ?
    I have the y axis driven by pulleys , does the x axis need some sort of rubber/vibration absorbing mount ? Suggestions ?
    Thanks Tom
    Jul 2008
    390
    Quote Originally Posted by painter View Post
    You can post them here, or if your question is on a specific driver, say Gecko, post it in that forum. Otherwise post in general electronics.
    General Electronics Discussion - CNCzone.com-The Largest Machinist Community on the net!
    I have a qustion too. Why did you decide to put a nut on the inside of the bolt instead of just tapping the bolt it to the steel frame? I.E. First pic of post #16.
    Dec 2012
    amish,
    It is tapped through the steel , and then nutted on th backside as a jamb nut, all of my connections are double nutted to eleminate superficial problems, when things are'nt working out the way I want, later on I don't want loose mechanicals to be the cause of the infection...( kind of like a nuts and bolt Flue Shot) When I am done every nut will be replaced by a nylock, double security , cheap insurance!!
    Tom
    Jul 2008
    390
    amish,
    Tom
    Great idea! I'll have to do the same.
Page 1 of 3 123
  1. One years worth of pics and videos of my 43" x 98" MDF machine FIRST BUILD!!!
    By Grunblau in forum DIY CNC Router Table Machines
    Last Post: 03-23-2018, 06:35 PM
  2. New CNC machine build (big pics)
    By ckm in forum Vertical Mill, Lathe Project Log
    Last Post: 04-30-2012, 11:49 PM
  3. My first build log of my belt drive DIY CNC Machine - PICs
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 03-23-2012, 05:10 PM
  4. Replies: 4
    Last Post: 12-17-2011, 04:27 PM
  5. Plug-in Hybrids - 95 year break-even cost for fuel efficiency
    By dynosor in forum Environmental / Alternate Energy
    Last Post: 04-23-2008, 08:05 PM
