Built a machine with 1200oz steppers two on X one on Y and one for Z, driver boards are Gecko G201's controlled by a PMDX.com 131 breakout board and 34volt 20amp power supply (I had been running it at 68volts but dropped it down at the advice of Mariss) all controlled by Mach2 steady at 25,367mhz with X and A drives slaved. Steps are set to 10,020 which seemes to be the right number after measuring numerous times, I have the Velocity set at 2 and have tried almost every variable between 1 and 2.5 with Accelertaion set between 5 and 22.5.
The problem I am having is that when I run the G-code (any code) if I run at over 80ipm I get what I think you would call stalls, not at the same point every time or same axis for that matter but more often the X or A which skews the gantry. Every thing runs smooth as silk when jogging at any speed (tested upto 149ipm) but when running a job even an air cut I get inconsistant stalls. Any help would be appreciated.
BTW motors are direct connected to 5tpi screws which have been triple checked for any kind of mechanical problems. Thanks in advance.
Robert
Also forgot to mention although the motors apear to stall two grown men cannot stop (or even hesitate) the gantry from moving at any speed!
