Well hello all,
Wow.. I hope this is in the right place, don't think I've ever seen a forum with so many sections!
I'm currently designing my own cnc router. I'm on a tight'ish budget hence the diy route.
OK, after advice really and does' & don't on what I'm currently purposing...
Here is a list of my parts so far.
Y Bed (1200mm) - 2 x 30mm bright mild steel rods with linear bearings
Y Bed motor - 23 Stepper motor
Y Bed thread - M10 Stud 1.5 pitch
X Bed (830mm) - 2 x 20mm bright mild steel rods wit linear bearings
X Bed motor - 23 Stepper motor
X Bed thread - M10 Stud 1.5 pitch
Not got to the Z axis yet as I'm still designing it. My concerns are flex in the round bar's I've chosen 30mm round bar (mild steel) because of the price really and the diameter to try and reduce flex. For past experience would I be ok with this? And 20mm on the X axis (trying to reduce the weight on top)
The whole construction will be out of 30mm square extruded aluminium which works out about £6 a metre I think.
The router will be a stripped down Draper 1200w one for now as that's what I've got.
Design is being done in inventor which I started learning last week.. lol so that's a challenge in it's self.
Any help / advice would be most welcome :-)
thanks,
Steve
