588,620 active members*
5,509 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > I am using a DRO glass encoder for gecko 320
Results 1 to 6 of 6
    Mar 2007
    574
    I am using a glass encoder 5 micron to drive my 320 gecko.
    It work fine on the kitchen table but now the question is how to send the signal back to my DRO ?
    I use the sn75176A differential bus transceiver i have A,B and NOT A, NOT B.
    I use AB line for the gecko and will use notAnotBfor the DRO
    I want to use the power suply of the DRO for the encoder
    I will have to put a 470 ohms to the term6 and term7 on the gecko
    question:
    I will have to connect the ground of my encoders DRO to the gecko encoder- do this mean that the ground of my gecko will be linked to the ground of the DRO?
    if so what is the danger ?
    I presume that the external(DRO) 5V should not be connected to encoder+
    corect?
    24222
    Essentially it looks like you have it correct.
    The 5v supply commons of each will have to be connected together.
    The DRO supply common may be at Earth Ground potential, this may or may not be a problem, depending on what method of grounding or isolation you are seeking.
    The +5v should not be connected together.
    Depending on the internal condition of the drive input, you may not need a pull up with the 75176?
    Al.
    Albert E.
    Mar 2007
    574
    I am not very confident to link my friends DRO with the notorious fluctuating ground of the 320 when used with more than 4A servo in my case 8.8A 72V
    Mariss address the problems but i never could find the circuit he posted !
    http://www.cnczone.com/forums/showpo...48&postcount=9
    Also is it good practice to use another 2 opto on the same line one already in the gecko and another one to isolate the ground?
    24222
    If you are concerned about establishing Earth ground isolation, check the 5v supply common of the DRO and see if it is referenced to Earth Ground or not.
    If it is not, there should be nothing to worry about.
    I reference all my systems to a common point Earth Ground anyway.
    Al.
    Albert E.
    Mar 2007
    574
    ok i will check that
    Mar 2007
    574
    hello,
    the linear encoder of the DRO is connected to the ground!
    so my gecko is also connected to the ground so crossfinger and go
  1. Gecko Under Glass
    By Clockwork in forum G-REX
    Last Post: 07-30-2016, 04:49 PM
  2. servos motor gecko DRO encoder?
    By mike10 in forum Gecko Drives
    Last Post: 03-13-2009, 03:46 AM
  3. External encoder power in a Gecko 320 System
    By bharbour in forum Gecko Drives
    Last Post: 10-15-2008, 05:29 AM
  4. Mounting rails on glass - how flat is glass?
    By Swiss in forum Linear and Rotary Motion
    Last Post: 07-25-2008, 08:10 AM
  5. gecko / servo / encoder wiring
    By shnitzel in forum Gecko Drives
    Last Post: 07-19-2007, 12:02 AM
