yea, in theory i can see where you would come up with that.. and its not a terrible idea, i once saw a guy that used springs.. but just like Ray said, its gonna have other effects that might not be so disireable..
not to mention that when you remove power from the drives, that the weight might pull the table all the way to one corner of its travel..
also you've gotta think about the vectored forces.. lets say that you pull on x in the + direction, at the center of the y travel, then when you get to y++ max or y-- max, the weight will be pulling, at a vector angle in the y- direction when your at y++max, and in the y+ direction when your at y--max, thus adding even more load to things, and this vectored force will vary all along the travel of the axis...
then theres all the cable and pullies and complicated-ness of it, and it quickly becomes more trouble to upkeep than just fixing things the right way.
again, i dont want to belittle your idea, keep thinking, but on this one, i think the added complexity and potential other drawbacks might out weigh the gains....
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
