588,208 active members*
4,222 visitors online*
    Sep 2007
    48
    Removing Z-Axis backlash
    While I still have the older style dovetail Z-axis, I figured this simple mod could help anyone with a taig using the original leadscrews:
    It's a pretty straight forward solution, brass nut with a pin on it's OD to prevent rotation while still allowing translation in the Z-axis's main body. The body was bored with two steps, one to locate and seat the compression spring and the other to create a slip fit between the brass nut and main body. I quickly threw the completed assembly back on the machine and tested it with a DTI w/ .0005" graduations with zero visible backlash on the indicator.
    While some may use just the weight of the motor to attain a similar effect, I have counterweighted my spindle's motor to remove the moment created on the main body. This allows the gibs to be tightened quite a bit more than before and helps to keep the spindle true to the workpiece. I've been doing alot of 3D surfing on the parts I work on, so removing the backlash and optimizing the rapid speeds of the Z-axis has proven to be critical in reducing run times. I hope this helps anyone else running into the same issues :cheers:
    Sep 2006
    1738
    Nice post, wouldn't mind getting this done on my newer (few years old) Taig.
    -Jason
  1. Removing 4th Axis from Table, Fanuc 0i
    By Jay Kyle in forum Fanuc
    Last Post: 08-10-2022, 03:04 PM
  2. Removing backlash on X & Y by using weights?
    By svarzaru in forum Benchtop Machines
    Last Post: 02-24-2009, 02:54 PM
  3. removing nut on x axis
    By Kevin Moore in forum Syil Products
    Last Post: 10-08-2008, 03:35 PM
  4. Z axis backlash.
    By wyc in forum Syil Products
    Last Post: 09-04-2008, 08:20 PM
  5. Z-Axis Backlash
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 05-19-2003, 02:42 AM
