587,560 active members*
3,488 visitors online*
    Jul 2005
    54
    create text file in macro
    how can we create text file which includes some variables, with macro on cnc ?
    May 2007
    781
    If you mean to create a text file on a computer that contains data from the CNC control. The only (standard) way, standard being relative, is to have the computer connected to the control thru the serial port. And have a program running on the computer that will take input from the serial port and put it in a file. Then on the control you use the POPEN, BPRNT or DPRNT, and PCLOSE commands to output the data.
    In the days of DOS the computer could be told to accept any input from the serial port as if it were coming from the keyboard in which case you would not need a program running on the computer, but I would have to dig deep to figure out how to do that, something with the mode command I think.
    Jul 2005
    54
    thank you Andre' B
    Thank you very much for interesting
    I have Solved
    Problem is [54]
    Who bady know What is the meaning [54]
    Correct writing for me
    :7777
    #500=#3901
    #501=#3011
    #502=#3012
    #503=#4115
    POPEN
    DPRNT[#500[54]]
    PCLOS
    M30
    My Control is Fanuc 21 i TB
    Thank you very much
    Mar 2006
    107
    Quote Originally Posted by Osmanselim View Post
    I have Solved
    Problem is [54]
    :7777
    #500=#3901
    #501=#3011
    #502=#3012
    #503=#4115
    POPEN
    DPRNT[#500[54]]
    PCLOS
    M30
    Thank you very much
    [54] means that there will be punched out 5 characters befor decimal point and 4 characters after decimal point
    So if you have in variable 123456789.123456789
    youl will get out 56789.1234
    Sorry for bad english
  1. How do I create a DFX file
    By Blacksunshine in forum DIY CNC Router Table Machines
    Last Post: 06-27-2008, 01:32 AM
  2. Text macro
    By paptep in forum Haas Mills
    Last Post: 04-19-2007, 12:48 PM
  3. Text file with NC code - what's needed so that Mazak can run this?
    By kevotron in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 09:45 PM
  4. HOWTO: Create text in Radius
    By Gujustud in forum BobCad-Cam
    Last Post: 03-22-2005, 05:04 PM
  5. Saving a Text file?
    By Scott V in forum BobCad-Cam
    Last Post: 11-24-2004, 03:27 AM
