588,662 active members*
4,863 visitors online*
    Sep 2005
    249
    Correct Relay board for Mach and router
    I have found all kinds of research on how to setup a relay board and router, but not much on which ones I should get.
    I have a CNC4PC breakout board, and am looking to get one of their Relay boards. I'm looking at the following:
    http://www.cnc4pc.com/Store/osc/prod...products_id=50
    I'll be using this to control a starnd PC 1.5 HP router. Will this relay board suffice? It says it has a 12 amp "triac" Does that mean it handles up to 12 amps?
    Also, have have a PC 3 1/4 HP router, will this handle that also? I suppose it will, providing I don't put it under full load.
    Any help would be greatly appreciated.
    If you look in the manual, it says it's only good for 5 amp devices.
    This one can handle your router plus 3 other small devices (5 amp). Looks like the only one they offer that'll work for you.
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=132
    Sep 2005
    249
    Thanks for the reply Gerry! I see what you're talking about in the documentation. Should have read that more carefully. it looks like that card is pretty robust and a good deal. Plus, I'm future proofing some with having three additional switches.
    Apr 2007
    327
    William,
    I would email Arturo directly, he knows his product very well and may have suggestions as to what will work for your particular application.
    Gary
  1. CNC4pc Solid State Relay Board.
    By Smackre in forum CNC Machine Related Electronics
    Last Post: 05-21-2006, 09:19 PM
  2. cnc4pc relay board question
    By Stuff-Builder in forum CNC Machine Related Electronics
    Last Post: 03-17-2006, 04:17 PM
  3. Parallel Relay Board & Z-motor brake issue
    By Liv2fish2 in forum DNC Problems and Solutions
    Last Post: 02-06-2006, 06:35 PM
  4. Quad SPDT Relay Board - 15A 250VAC Contacts
    By winfordeng in forum News Announcements
    Last Post: 07-26-2005, 02:08 PM
  5. Mach2 & Rutex relay board.
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2004, 07:50 PM
