Hi I stripped the plastic gear #209 on the parts diagram. Grizzly says 6-8 weaks for replacement. If anyone that has converted to belt drive has one laying around thay would like to sell . Let me know.
I did the same but I was planning to go with a belt drive so I just got Hoss' belt drive plans and ordered the parts to do that. Not a drop in replacement but will give me more top end RPM for aluminum and Delrin.
Hoss also has a mod for substituting both the intermediate and motor gear with steel with part #s etc. Look under projects at g0704.com
My plastic intermediate literally had no teeth left on it!
cheers,
Michael
Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
www.EclecticAngler.com | www.ReelLinesPress.com
sorry, I looked kd but both my old gears are long gone.
same with the plastic internal intermediate gears.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
I was looking at qtcgears . the stock motor gear is 30mm dia 20 touth the outher gear that stripped is 50mm? 38 tooth .
on the qtc link a 50mm dia has 48 teeth and a 30mm has 28 teeth.
My question is would that fit with out modding the motor mouht and would it run the spindle faster or slower. I know the gears would need moded that is not a problem as I have a lathe.
Good news just got an email from grizzly. my gear has shipped. :banana:
Yea you really can't trust grizzly on what they have in stock unless you actually place an order
Well the gear just arived. Now time to get my mill back togather and start making chips again.![]()
I got the #209 gear if anyone wants them.
I have a bunch of parts if anyone needs something
Headstock parts
Stock motor
stock gears both small and big
Control box complete I think.
I converted to belt drive and CNC I have a lot of stock parts left over.
Let me know what you need and we can work something out.
I am located in Henderson, NV.
Joseph
