Hi Guys,
I am having trouble getting from a DXF that I drew into usable G-code.
I have attached the DXF file and G-Code file for reference.
I used autocad for the DXF file and BobCad for the G-Code generation.
Mach3 is used to check the code generated.
I assume i am doing something fundamentally wrong as i don't think it should be this hard to get it right. The issue i am seeing is that sometimes i don't get a correct path and when i finally got something that looks right, the scale was out by 10, so 250mm is actually 25mm on Mach3.
/Mikie
