Sounds very nice. I must say your welding and grinding of those box corners looks really good.
I have had some issues with my Solsylva, mostly getting the x screws aligned properly at first, but I can't say I ever had trouble with the x belt. You using two steppers to get more power, or did you have trouble with the belt itself on the oak version?
Once I had a touch probe routine I downloaded for Mach go south and the probe kept going past the surface of the (aluminum) material. I was standing right there with my hand over the estop, but even before I could hit it, it really built up some force. Ruined the bit. What gave, though, was the Z belt - it snapped and went flying. Always since kind of thought that the belts were a type of safety valve. Even though I have spares for all three belts, that's the only one I've had to replace. I fixed the touch probe routine and its been ok since, but I still have my hand right over the estop any time I click the zero-Z button.
In your drawing, do the screws go through the gantry sides?
PS - You looked into Gerry Grzadzinski's (Ger21) new 2010 Mach3 screen set? Give your new table a new screen look as well!
"72.6 per cent of all statistics are made up on the spot." - Steven Wright
