587,207 active members*
3,028 visitors online*
    Mar 2007
    Sherline lathe question
    Hi everybody. Quick question about my Sherline lathe. The Slide screw insert on the lathe table requires the motor to be turned many times before it changes direction. Is this an understood design characteristic or is this a problem w/ my lathe. It would seem like an incredible amount of backlash, but it looks like there's no way to combat it so I figured I'd reach out and ask. Thanks for any and all responses.
    Brian
    May 2007
    6
    Sherline Backlash
    Hi Brian,
    Sherline is legendary for backlash. I assume you're using the power feed, hence your reference to the motor turning.
    I don't have the motor but there is always .25+mm backlash in the saddlenut. Even with a brand new saddlenut I routinely get .12mm which quickly wears out to the .25mm mentioned.
    Sherline now offers, however, a leadscrew backlash lock. See the following link for more info and a part number. I bought one for my mill but haven't installed it yet so I can't tell you how well it works.
    http://www.sherline.com/4417Zpg.htm
    Les Brown
    Feb 2006
    1072
    Quote Originally Posted by bnalls View Post
    Hi Brian, something is definitely out of adjustment with your lathe. It should be possible to get .003-.005" (.08-.12mm) backlash with the stock lathe.
    My lathe is a stock 4400 with CNC, and I can regularly turn parts to .001-.002" tolerance (backlash measured and compensated in TurboCNC.) If your lathe is CNC, are you sure that the leadscrew support bearings are adjusted with no play?
    Best regards,
    Randy
    Mar 2007
    Thanks for the replies! The table was indeed not tightened towards the center of the screws is a nut apparently but I have yet to fix it. Thanks for the responses!
    Brian
  1. Sherline Cnc 4400 Lathe
    By STIELJTES in forum Mini Lathe
    Last Post: 08-09-2009, 12:59 PM
  2. Sherline, Grizzly, Harbor Freight Sieg lathe
    By twocik in forum Mini Lathe
    Last Post: 06-20-2007, 07:24 PM
  3. Sherline 4000 Lathe
    By sleepy23 in forum Mini Lathe
    Last Post: 11-09-2005, 10:44 PM
  4. Sherline Mill and Lathe on Ebay
    By Halfnutz in forum Benchtop Machines
    Last Post: 05-16-2005, 02:10 AM
  5. Choosing a Sherline mill or lathe
    By kdoney in forum Benchtop Machines
    Last Post: 04-19-2003, 04:36 PM
