Hi all,
I am choosing to place a bleed down resistor over my capacitors, size of the power supply is 12.5A and 45VDC.
I have a 100 Ohm resistor rated at 5 watts, which will draw .45A, what I cant work out ( DUH!) is what the voltage drop will be.
Power supply will be running 3 stepper motors at 2.53A and 4.8 volts each.
If this 100 Ohm resistor is not the best one to use please suggest a better option.
Pretty simple request for all those out there that seem to have good knowledge dribbling out of every pore on thier bodies![]()
