588,345 active members*
5,592 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > PU Polyurethane resin / Epoxy alternative
    Jun 2012
    31
    Hi everyone
    I'm currently designing my future mill (see appropriate section) which will probably made out of EG.
    Maybe this topic has already been discussed, but I don't see a dedicated thread, so here I go.
    I see there is only epoxy being used so far. Considering the prolific choice of polymer resins out there, I am pretty confused. I understand Polyester has a consequent shrinkage coefficient which is not suited for casting unless you don't mind warping.
    Yet, Epoxy and Polyester resins are mainly used in laminating process. For casting purposes, there are specific resins such as Polyurethane.
    I'm not a specialist concerning polymers, but it seems that Polyurethane has interesting properties, it seems decently rigid, and also features low shrinkage, which is the reason it's used for casting. Thus, you can find special casting Polyurethane casting resins such as this one :
    Water Clear Polyurethane Casting Resin for Embedding and Rapid Prototyping - Easy Composites
    There is also a fast curing one, but as the polymerization is exothermic, that's not good for us.
    It seems that the price is comparable to epoxy resin, and maybe even a bit cheaper.
    So what do you specialists think ?
    Greetings from France
    Cyril
    Jul 2007
    1602
    I seem to remember there was a discussion about that in the big e/g thread and the consensus was to stick to epoxy. AFAIK no one is advertising poly*/granite bases...
    bob
    Jun 2012
    31
    I haven't seen anything about that either commercially speaking yet polyurethane seems more used in casting than epoxy. I gues I'll check in the "master thread" to see if anyone has tried yet.
    Oct 2005
    2392
    Polyurethane is a lower quality result, it has much lower strength and extremely low adhesion. So in a composite like EG it will break very easily.
    Also PU tends to set very quickly, which might be a benefit when casting little ornaments and statues, but would be a nightmare when trying to mix/vibrate/degass an EG composite.
    It's also not much cheaper than epoxy. Add all that up and you'll see why nobody is using PU to make big expensive EG machines.
    Jun 2012
    31
    Well, I think I got my answer, thanks
  1. choosing the correct epoxy resin
    By jerrywi in forum Momus Design CNC plans
    Last Post: 04-07-2012, 02:23 PM
  2. Epoxy resin and Silicone Rubber mold help
    By Ikaros in forum Moldmaking
    Last Post: 08-23-2011, 12:18 PM
  3. Solid material alternative to epoxy?
    By Sammy Ple in forum Vacuum forming, Thermoforming etc
    Last Post: 10-03-2010, 11:29 AM
  4. Self leveling epoxy resin-wear characteristics?
    By Splint in forum Uncategorised MetalWorking Machines
    Last Post: 07-23-2007, 02:11 PM
  5. Epoxy resin floor paint and MDF.
    By Oldmanandhistoy in forum DIY CNC Router Table Machines
    Last Post: 02-25-2006, 09:09 PM
