587,941 active members*
3,085 visitors online*
Results 1 to 9 of 9
    Sep 2004
    412
    Mach3 on Laptop without Parallel Port
    I'd like to upgrade my current mach3 pc and crt monitor with something a little easier to manage.
    I was thinking about getting one of the Dell mini 10's. Since the price looks good.
    Unfortunately, they mini10 does not have a paralell port.
    So, can I get a usb to parallel port adapater and be golden?
    Or??
    No, you'd need to use a Smoothstepper from www.warp9td.com
    Dec 2004
    1865
    Quote Originally Posted by Deviant View Post
    Or??
    NO
    A smooth stepper or other external motion controller will work but not a usb to parallel adapter.
    Laptops with pports can be problematic anyway.
    Get a used lcd and stash the tower under the desk if possible.
    I do sympathize with the space constraints of a small work shop especially when you stuff 6 machines in a space designed for 2.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Sep 2004
    412
    Ok
    That's what I was thinking. I was just hopeful that someone would tell me that X adapter is powered externally and would work.
    *mumbles*
    Is anyone using the smoothstepper successfully? I've looked at those in the past and it seems to still be in it's infancy.
    Dec 2004
    1865
    You can get a small form factor pc if space is an issue. Some still come with a pport or you can add in a pci card if needed. Just need to make sure you don"t have video issues.
    Other people can tell you which one to get.
    Mike
    If you don't need more than 25Khz, a Dell GX150 with a 1Ghz processor works great and are $10-$50 on Ebay.
    Sep 2004
    412
    Mostly I was looking at space. I wanted to mount the laptop on a little arm that is attached to the table.
    Currently I have a ~2.5ghz machine with crt. I guess I'll replace the crt with a lcd, maybe a touch screen one.
    I'm not quite stepping over myself, but when I have the car/motorcycle etc in the garage. It starts to get very cramped.
    Dec 2004
    1865
    Wait until you start getting more machines in the garage.
    You will need to put the car/motorcycle outside under a tarp.
    Mar 2009
    31
    I mounted one of thesehttp://cgi.ebay.com/Desktop-Table-LC...d=p3286.c0.m14 to one of the legs of my CNC and bolted a piece of plywood on the top of it. It holds a 22" LCD, keyboard, and mouse. A small Dell 2.7GHz PC sits on a shelf under the main CNC table. WHen I'm done, the LCD is removed and the whole arm rotates over the table. The CNC is on casters so I can roll it out of the way.
  1. PCMCIA Parallel Port on Laptop
    By Jim Estes in forum Controller & Computer Solutions
    Last Post: 09-29-2009, 04:38 PM
  2. Mach3 Not Working At All With Parallel PCI Port
    By Brenck in forum Mach Software (ArtSoft software)
    Last Post: 07-15-2009, 01:43 AM
  3. laptop usb parallel port
    By dgalaxy in forum CNC Machine Related Electronics
    Last Post: 04-09-2008, 10:00 PM
  4. laptop pcmcia parallel port works
    By craigtx in forum Computers / Desktops / Networking
    Last Post: 12-12-2007, 08:31 PM
  5. Mach3 and Parallel port
    By Me2 in forum Mach Software (ArtSoft software)
    Last Post: 01-28-2007, 11:38 PM
