Hi. My learning of v23 is going well now - I am posting and doing jobs. I really like it!
One problem though. I am using the manual feeds and speeds as I cannot get the system auto to work. ( I have set up the cutting speeds and tooth load values).
Now when I edit prior to toolpath I try to select a pre entered system tool eg number 15 C endmill . The only way I can see to open the system tools is to click manual tool - opens select tool - select eg number 15 C . but the system auto feeds and feeds do not alter from the previous selection. And if the system tool button is clicked to remove select tool button (to see if that is needed) the tool reverts to tool number 1 again. And the system feeds remain unchanged.
I have watched the video on this several times, but it glosses over the selection details a bit - it does not expain this in enough depth.
