587,375 active members*
3,072 visitors online*
    Aug 2021
    5
    FCA520ALR battery dead
    Hello everyone, i have been asked to try to help with a meldas fca520alr which lost his battery charge
    I have an LK4 file, but i dont know which software to use in order to download it into the controller memory
    Any clues please ? Thank you !!
    Nov 2012
    367
    Re: FCA520ALR battery dead
    I know this is an old thread but....
    I have an M3, not an M5, but that should be academic.... You can use a variety of different software programs to do this, but some of the ones that are specifically designed for CNC have some great interfaces. Most of the time, you are talking about a serial connection. DNC-Precision has a demo version that will work. I use QuickLink2000 from MicroCIM, and I *think* they have a demo. There is another one that did a stellar job of detecting communications protocols and setting up your port automatically, but I don't recall the name off the top of my head. The point is, you'll need *something*. Microsoft no longer provides HyperTerm in the more current windows releases. Note that serial is also not common on most modern computers. I personally have had good luck with USB to serial converters (FTDI or Prolific chipsets). I wrote up a document that will walk you through a lot fo the setup information for serial and provide a suggested USB to Serial converter. However, this is really geared towards an M3 control. The good news is that Mitsubishi seems to have carried forward its basic concepts on the later controls though. This means that I think the document will have a lot of parallels. I'm actually curious if this is the case though. If you PM me, I'll send the document along, but I do want to know how useful it is. I'd like to alter it accordingly so that it can help others get out of a bind.
    Jul 2014
    11
    MrMetric
    Consegue enviar o procedimento para [email protected]
    Preciso aprender a fazer backup no Mitsubishi M60s
  1. TL1 dead battery
    By CMI10 in forum Haas Lathes
    Last Post: 10-05-2016, 04:49 PM
  2. Mazak M5 DEAD BATTERY -DEAD CONTROL
    By tired_iron57 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2012, 07:35 PM
  3. Battery dead AGAIN after less than a year (2-06MM)
    By xiondavis in forum Haas Mills
    Last Post: 09-17-2009, 04:35 AM
  4. EZ-Trak DX with a dead battery!
    By Retired Guy in forum Bridgeport / Hardinge Mills
    Last Post: 08-10-2009, 02:03 AM
  5. CPU dead battery
    By LT1TRUCK in forum Computers / Desktops / Networking
    Last Post: 09-10-2007, 12:47 PM
