588,548 active members*
5,678 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB15 tailstock alignment
Results 1 to 8 of 8
    Nov 2008
    Having difficulty aligning the tailstock on an Okuma LB15. This is a manual tailstock with a hydraulic quil feed. We have loosened the bolts and the gibs but still do not get it to budge. Any suggestions?
    Apr 2006
    825
    Get a BIGGER hammer?
    Dec 2008
    3142
    Quote Originally Posted by broby View Post
    Hey Brian,(chair)
    You bored ??
    emfgllc
    There should be windage screws on the front and back, loosen one then tighten the other to side-shift the upper part of the tailstock ( Quill body , not the base that slides along the rails )
    Apr 2006
    825
    yep!
    Could not resist the obvious dumb answer!
    May 2009
    14
    On the LB10 there are four bolts holding the tail stock on to the base that sets on the ways or bed. There is also a set of ways that take the play out between the base and the quill housing (They aren't real apparent). It may help if you loosen it to give yourself some room for movement.
    It is sort of tricky getting the little jib adjustment (wedge?) thing loosened. On mine there is a screw that tightens it. In other words drives the wedge in and removes all of the play. First you have to loosen that. Then you need to blow out of hole in the end of the jib. I cleaned mine out with a tap. Then I had to find a bolt and some washers to act as a puller to get it to pull out a little.
    P.S. On the LB10 the jib is up near the front bolt of the two bolts that tighten and loosen to allow the whole unit to sled forward or back. Right there between where the upper part meets the base.
    Once you get it line up close to being parallel with the spindle you can re-tighten it up. On mine it would help bring the whole unit into alignment. What I mean is when I had the center hole extended and dialed in it would help bring the rear end into alignment. It can be hard to check the alignment back there. Ideally the center should be lined up and parallel.
    We have a indicator made for lining up spindles at the shop I'm at now that is great. It allows you to chuck it and then a big long indicator needle fits down into the center taper hole. The good part is that you can rotate the spindle and keep the indicator dial faced up the whole revolution. You have to be a sort of contortionist with a regular dial indicator. It doesn't have a name on it and I don't know where they found it.
    I am guessing your tail stock is similar.
    P.S. I tried a bigger hammer before I remembered the jib adjustment thing-a-ma-jigger. The trouble is there is no swing room! Hee Hee
    May 2009
    14
    Blake Manufacturing Co.
    I found the spindle indicator that I mentioned in my previous post. It is the one you can read facing you while it is rotated around center. It looks like it runs $286.00. It seem like a deal to me.
    I guess mill guys would like it.
    Here is a link.
    http://www.blakemanufacturing.com/pages/aboutus.html
    Pricing link.
    http://store.blakemanufacturing.com/...uct_detail&p=2
    Apr 2009
    1262
    Get the Blake co-axial indicator. It's well worth it. You don't have to use a mirror and it doesn't give the droop error readings like on a mag base and indicator.
    Dec 2008
    3142
    Similar to the "Blake" but a lot cheaper @ $70
    link
    Strike the similar--it's the same
    and it comes in a box as well
  1. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  2. I need IGF manual or pdf for okuma LB15
    By cncldwms in forum Okuma
    Last Post: 10-24-2012, 02:20 PM
  3. SKT21LM Tailstock alignment
    By CNC RACING in forum Hyundai Kia
    Last Post: 04-29-2009, 07:53 PM
  4. Tailstock Alignment Question
    By tigermothracing in forum MetalWork Discussion
    Last Post: 09-05-2008, 03:49 AM
  5. tailstock (mis)alignment
    By ajbarrell in forum Shopmaster/Shoptask
    Last Post: 01-07-2007, 05:18 AM
